It is currently Mon Aug 04, 2025 6:23 am
PostPosted: Fri Feb 13, 2009 1:36 pm
By now I've read almost everything I could get my hands on about using waterstones. I know one simple way of flattening them is on a flat surface with some 120, 220 w/d sandpaper. Thing is, I don't have any right now. I do have the flattening stone that came with my Norton kit though. I'm a little reluctant because I read an Amazon review that said it's hardly flat and no good. I know those reviews can be a bit inaccurate sometimes, but I don't want to make more mistakes than I already have recently! :) Should I stay away from the flattening stone?
-John
PostPosted: Fri Feb 13, 2009 1:55 pm
Dunno.. I've had no issues so far with my Norton flattening stone..
PostPosted: Fri Feb 13, 2009 3:30 pm
PostPosted: Fri Feb 13, 2009 4:49 pm
Not sure if the one Lee Valley sells is a Norton or not .. but I have one and so far it works great - took the valley out of the stone in no time ...
PostPosted: Fri Feb 13, 2009 5:32 pm
I just find it as being odd that norton who puts out some good stones would have a flattening stone that didn't work??? idunno
PostPosted: Fri Feb 13, 2009 5:54 pm
I would give it a try since you already have it. Just make some pencil lines on the stone and see if your flattening stone is flat enough to work well.
John my friend I suspect from reading your threads that you are in tooling-up mode and if this is the case with all that you may be purchasing why not try the one that you have and see if the value/utility is there prior to considering anything else.
PostPosted: Fri Feb 13, 2009 7:16 pm
I have one and it works fine. Of course I'm sure you'd do fine with sandpaper on glass, but then you'd own one less tool, and nobody wants that.
David White, Toronto
PostPosted: Sun Feb 15, 2009 9:05 pm
I use Todd's method.
Users browsing this forum: Bing [Bot] and 35 guests
